March 19, 2022 at 6:49 am
nm2141
SubscriberDear All,
I am beginner and going to make model on Ansys. I want to insert a cylinder within a tube. Would you mind letting me know how can I do so? The cylinder is going to be fixed within the tube.
I am kindly looking forward to hearing from you.
Best Regards,
Nima
March 21, 2022 at 4:25 amKeyur Kanade
Ansys EmployeePlease use SpaceClaim. You can find some tutorials on command Pull on youtube.
Please go through help manual for more details
Regards Keyur
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2588
2080
1315
1108
459
