May 8, 2021 at 10:05 am
May 10, 2021 at 2:48 am
Naresh Patre
Ansys EmployeeHello Luca
I think this could be possible through scripting. You can first create the centerline of the pipe and create a parameter for the radius of the centerline. Then Pull out a circular profile to create the solid pipe.
You can access the radius parameter in the script so that when you change the parameter value, the script would create a new pipe geometry. (You will also need to add a command for deleting the geometry at the start of the script so that every time to run the script, it starts from a blank session)
May 10, 2021 at 5:45 pm
luca
SubscriberThank you Naresh Patre
was hoping this to be already in some SC option.
Will investigate scripting option as I am a bit more into SC, still learning it.
Thanks!
3930
2649
1865
1272
610
