TAGGED: absolute-pressure, operating-conditions, tui-command
June 24, 2023 at 2:29 am
driftingninja
SubscriberHello,
I have a closed volume with an ideal gas mass flow inlet b.c. The simulation tracks nicely with experimental data when I have 'floating operating pressure' checked. The issue is I need to dynamically turn the floating operating pressure off during the run as the mass flow inlet b.c. just becomes a wall (valve is shut off) and another wall becomes a pressure b.c. (valve opens up) but the pressure b.c. is incompatible with floating operating pressure. Most of my dynamic changes are through TUI executions via cases under calculation activities. I was hoping to find a TUI command to turn the floating operating pressure on/off but could not find this as an option. Does anyone know if turning this on/off is possible via TUI? Journal? UDF?
Thank you!
June 26, 2023 at 6:39 am
SRP
Ansys EmployeeHi,
You can use TUI: define/operating-conditions/operating-pressure
For more details you can check fluent text command list: Chapter 2: define/ (ansys.com)
Thank you.
June 26, 2023 at 7:57 pm
7592
4440
2953
1427
1322
