August 3, 2021 at 11:19 pm
Ansystrial
SubscriberHello,
I want to add new material to the Ansys Additive 2021 R1 library and followed the steps in the manual of the Material Tuning tool. I prepared the three needed files (two .csv and one .json) and populate the cells as directed. However, I got n error that the simulation failed because of "Invalid simulation parameters". Would you please help me troubleshoot this?
August 18, 2021 at 6:15 pmGovindan Nagappan
Ansys EmployeeCan you insert an image instead of attachment to show the problem?
August 18, 2021 at 6:23 pmAugust 23, 2021 at 5:40 pmGovindan Nagappan
Ansys EmployeeSomething in the input is formatted incorrectly or out of range. If the Ansys version is earlier than 2020 R2, the laser speed of 350 mm/s is out of range.
August 23, 2021 at 8:21 pmMarch 1, 2022 at 6:38 amBorjaAf
SubscriberHello Like I followed the steps in the manual and I keep getting the following error message: 'maxError is outside allowed range of [0.01, 0.2]'. However, I think it dosen't even calculate the error of the first parameter combination because the error appears inmediatly after clicking 'Start'. The following image contains my experimental data file, if it's any help.
Viewing 5 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
