January 1, 2023 at 5:35 pm
Ak Muhammad Adam Pg Hj Ahmad
SubscriberOriginal post is here https://www.reddit.com/r/ANSYS/comments/zy3t2i/infinitely_increasing_power_coefficient_with/?utm_source=share&utm_medium=ios_app&utm_name=iossmf
Hello friends,
I am attempting to run a simulation using a whole rotor geometry and i was told to add inflation in my meshing for accuracy because my current mesh resulted in infinitely increasing torque on rotor blades with respect increasing angular velocity.
However i am unable to employ inflation on my turbine properly, can i get a guide on how i can apply inflation on complex geometry such as a rotor, with turbine blade and hub connected
January 2, 2023 at 5:24 am
Keyur Kanade
Ansys EmployeePlease check following videos
Ansys Meshing Sizing:
Ansys Meshing: Inflation:
Please go through help manual for more details
Keyur
January 2, 2023 at 5:40 am
Nikhil Narale
Ansys EmployeeHello,
Can you post some images of your geometry and the existing mesh in the comments?
I would recommend you to assign named selection to the rotor surfaces at the CAD level. With this, you can explicitly add boundary layers on the rotor surfaces (and not on hub).
Also, I would recommend you to use Ansys Fluent Meshing Watertight Workflow.
Check out this free course on how to add boundary layers (inflation layers): Add Boundary Layers - ANSYS Innovation Courses
Thanks!
Nikhil
January 2, 2023 at 3:21 pm
January 3, 2023 at 2:57 am
SubscriberHello Ansys employee,
Any new advice, you can help me with?
January 3, 2023 at 4:37 am
SubscriberDo i need to apply sizing along the edges on the blade in order for this to work? i tried to follow the video but as u can see the blade geometry is not as simple as box and cylinder please advise me on this dear ansys employee keyur and nikhil
January 3, 2023 at 5:36 am
Keyur Kanade
Ansys EmployeePlease use tetrahedron method. Then use inflation with aspect ratio method.
Keyur
2524
2066
1279
1096
457
