December 22, 2022 at 8:29 am
December 27, 2022 at 1:22 am
manu prabha anand
SubscriberAny one know about this?
January 3, 2023 at 5:20 pm
rfblumen
Ansys EmployeePlease refer to TurboGrid Tutorial 7: "Secondary Flow Path Meshing". You can download TurboGrid tutorials from the Ansys Customer Portal (follow the links for tutorial materials). You can define a secondary flow path in BladeEditor, transfer the geometry to TurboGrid and mesh the secondary flow path there along with the main flow path. By default, the secondary flow path geometry represents a this periodic wedge.
You can also define the secondary flow path geometry in a different geometry tool, mesh it in Ansys Meshing or similar, and import the mesh into CFX-Pre along with the TurboGrid mesh for the main flow path. However, using the approach above (using BladeEditor) is a more integrated approach.
January 3, 2023 at 10:23 pm
manu prabha anand
SubscriberThank you for the reply
2620
2098
1323
1110
461
