Preprocessing
Preprocessing
TurboGrid ERROR. Minimum distance s
    • rodriguez
      Hello everyone,
      I am currently working on a wind turbine blade and would like to mesh it with Turbogrid. This has a cut-off trailing edge and a flat tip.
      But when I want to import the geometry from DiesignModeler into Turbogrid I get the error message "Parameter out of bounds. Minimum distance s requested =2.56965 e-005".
      My guess is that the dimensions of the cut-off trailing edge and the flat tip are so small relative to the entire domain that they are below the possible accuracy of Turbogrid/DesignModeler.
      Any ideas on how to overcome this problem?
      I would be very grateful for any help.
      Regards
    • rfblumen
      If this is an industrial sized wind turbine blade, it sounds like perhaps the cut-off trailing edge is resembling a sharp knife-edge.  Some possible workarounds:
      -Turn off the "Cut-off or Square"  trailing edge definition in TurboGrid.  Using a different topology for the trailing edge may avoid the error
      -Try scaling up the geometry in DesignModeler by a reasonable value such that the mesh generates in TurboGrid.  Scale the mesh back down in CFX-Pre.
      -Modify the geometry in DesignModeler to avoid this knife edge (if that's what's causing the issue).  Dimensions that small for such a large geometry aren't realistic
