Turbomachinery Fluid Flow cfx-solver exit code 2
    • PeterSlotwiner
      I've recently started using ANSYS to model the fluid flow of a axial compressor design and am having trouble with the solution portion of the 'Turbomachinery Fluid Flow' Analysis. I've made sure the mesh is less than the student limit on nodes and all other parts seem to generate no errors. I've attached the out file, please let me know if there are any other documents/pictures that could help solve this issue.
      Thanks,
Viewing 0 reply threads
