Turbulent boundary condition
    • raju.chowdhury
      How can I calculate the turbulent intensity of high speed compressible gas flow? I don't have the data for velocity at inlet. I only know the mass flow rate and pressure at inlet.
    • vinayak chauhan
      Assuming you have a uniform cross-section and isothermal conditions u can calculate the outlet pressure by applying bernouliis equation for compressible flow analytically and attain pressure at outlet , which you can use further in your k-epsilon model. This can be used if you have a simple model.
      I hope it works.
      thanks,
      vinayak
