November 7, 2017 at 2:48 am
mmorg41
SubscriberI am working on simulating a transient flow that is compressible and turbulent through a pipe. You can think of it like an explosion on one end of the pipe and I am trying to simulate the fluid in the rest of the pipe. I want to make sure I have my viscous model setup correctly. Can someone please give me some advice on the best viscous model to use? Thanks!
December 16, 2017 at 1:29 pm
José Mantovani
SubscriberHello mmorg41, below have a two references to you find the correct set up for turbulence model!
https://br.comsol.com/blogs/which-turbulence-model-should-choose-cfd-application/
https://www.engineering.com/DesignSoftware/DesignSoftwareArticles/ArticleID/13743/Choosing-the-Right-Turbulence-Model-for-Your-CFD-Simulation.aspx
Good lucky!
Mantovani.
December 16, 2017 at 11:27 pm
Raef.Kobeissi
SubscriberA short answer would be the SST K Omega model, it deals with adverse pressure gradient better than K epsilon and is not sensitive to inlet boundary conditions as K Omega. Obviously my ansert is a bit simplistic and a good read about turbulence would explain it better.
Cheers -
January 5, 2018 at 3:01 pm
Raef.Kobeissi
Subscriber1 additional point: have you used the density based solver?
Cheers
2706
2146
1357
1148
462
