January 30, 2023 at 11:33 am
Lucas van Rossum
SubscriberDear All,
I have been working on a ansys fluent model of 2D airfoil. To compare the different turbulence models i have been trying to acquire a variety of contours but have been running into problems with this. Especcialy the turbulent viscosity contour has been giving me strange results. Does anyone know what might be the problem with my simulation?Kind regards,
Lucas -
January 30, 2023 at 4:02 pm
Ansys EmployeeCan you do a mesh display, walls only and post the result?
January 30, 2023 at 5:12 pm
Lucas van Rossum
SubscriberDear Rob,
Did my previous response meet your request?
January 30, 2023 at 4:43 pm
Lucas van Rossum
Subscriber -
January 30, 2023 at 5:15 pm
Ansys EmployeeDid you form a multibody part (DesignModeler) or use share topology (SpaceClaim) before meshing? I can't see a wall & wall:shadow pair so it's not quite as easy to fix as it could be.
January 30, 2023 at 5:18 pm
Lucas van Rossum
SubscriberI dont think i used any of those things since i have not heard of them before. I imported the airfoil using the 3D curve option in the geometry application. is there a better way?
January 30, 2023 at 5:25 pm
Ansys EmployeeThat bit is OK, it's how you formed the outer region that's probably an issue. Have a look at the geometry tool tutorials, you need to ensure the outer region is continuous to avoid blocking the flow.
January 30, 2023 at 5:43 pm
Lucas van Rossum
SubscriberCould you kindly provide me with the specific website you are referring to?
January 31, 2023 at 11:13 am
Ansys Employeehttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/main_page.html You'll need to launch Help from within an Ansys product to get a token (cookie) to then use the link.
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5384
3363
2471
1310
1022
