Turn imported load in non-tabular data
    • hansophxy
      I have imported a temperature load distribution from a precedent transient thermal analysis in a static structural analysis at a certain point in time. I apply the load as "ramped" in one load step.
      Since I have a model with very significant different non-linearities, obtaining convergence is very difficult. I now suspect buckling issues to be the cause on non-convergence. So I wanted to use the Arclength algorithm and see if I can obtain convergence. But that algorithm does not support tabular loads in Ansys. Does anyone know how I can apply the temperature load without having to specify the source time in the table?
      Thank you in advance, best greetings!
    • Ashish Khemka
      Forum Moderator
      Please see if the following link helps:
      Arclength method-Tabular Error ÔÇö Ansys Learning Forum
      Regards Ashish Khemka
  • The topic ‘Turn imported load in non-tabular data’ is closed to new replies.
