June 24, 2019 at 10:30 am
LGrahamanderson1995
SubscriberHi, I'm trying to download the geometry file for the film cooling tutorial. when I go to download it, it just takes me to the ansys website -
June 24, 2019 at 10:40 am
Ansys EmployeePlease can you post the image into the text: staff are not allowed to open attachments. Which code & version are you looking at?
June 24, 2019 at 10:51 am
June 24, 2019 at 10:53 am
June 24, 2019 at 2:51 pm
Ansys EmployeeWe took all of the tutorial materials off the Customer Portal a while back, so you may have found a rogue link somewhere.
Looking at the text I think that's the documentation level tutorials as opposed to the training equivalent so aren't on the archive here that came through from Fluent Inc and weren't updated beyond about R12. Given the dimensions above you're probably going to be quicker building the model from scratch! Additionally the interface is very different as are all of the models so possibly not the best way to learn the software.
June 24, 2019 at 2:53 pm
LGrahamanderson1995
SubscriberAh okay, thank you!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3812
2589
1843
1244
600
