February 6, 2018 at 2:15 am
sanusi
Subscriberhow will i create a ci engine geometry which will include parts like the chamber, valves, ports, cylinder head and piston head
February 6, 2018 at 2:24 am
February 6, 2018 at 3:46 am
sanusi
Subscriberthanks i really appreciate
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2116
1339
1118
461
