Tutorial on HFSS Circuit Simulation
    • Shahriyar_048
      I have designed a 2-port network for data transmission through body tissue in HFSS. I can import this to HFSS circuit module for the data link design. However, I am finding it difficult to generate the data sequence in HFSS circuit, and visualize the bit pattern. Could you please help on this? Thank you.n
    • rtk
      ,nCould you please share a little more details on your need, on the data sequence creation inside Circuit design?nIn Ansys Circuit design, you can use Project -- Data set, for the creation or importing any 2D or 3D data. nIs this the way you want to create the data sequence? Or any other way you are expecting? Please let us know.nnThanks,n
    • Shahriyar_048
      Hi,nI need this for creating a data stream for a Amplitude modulator. Say, a random binary sequence (10011100...) at 1 Mbps speed. Please advise. Thanks n
