February 17, 2022 at 7:03 am
satyajitc55
SubscriberHi guys,
I am beginner in maxwell and I want to create planar matrix transformer in it.
I understand that PExprt or PEmag are tools which I can use.
Between I found several tutorials for anays 2D and 3D for beginners.
But for PExprt or PEmag I did not get any document or video to help start setting up the things.
If you know any source like link, pdf etc for PExprt tutorial please share.
February 23, 2022 at 12:23 pmNavya C
I don't think there are any tutorials on PEXprt available in the open community.
But the Inbuilt help index provides very constructive details in PEMag use.
However, Let me check and get back to you if there are any tutorials.
If you are a paid Ansys Customer you can find the tutorials in the Ansys Learning hub.
Regards Navya
February 23, 2022 at 2:02 pmHoward
There are several design examples (tutorials) in the end of both PExprt and Pemag help manual. You could follow them.
HDLI
February 23, 2022 at 4:16 pmViewing 3 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2564
2080
1299
1106
459
