Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Twin Builder/Simplorer
    • waqas99
      I am getting no output power when I run the simulation in ANSYS Twin Builder. I have attached the ROM of WPT coils from Maxwell, and I have attached the screen shot of the Circuit designed in Twin, as well as the source design parameters.
      The WPT system designed is in Eddy Current.
      Please, provide your valuable feedback.
    • Ivonne Marti
      Hello waqas99,
      Please check that you are adding the Maxwell component via the following path.
      */ Select the menu item Twin Builder→ SubCircuit→ Maxwell Component→ Add Dynamic Eddy Current
      We have a workshop that describes step by step how to do the circuit analysis of a wireless charging. The direct link to this document is:
      https://jam8.sapjam.com/groups/YMfG652JOg4GxLo7hBmrag/documents/sdX4bMGqiNY0rAbclFTgjN/slide_viewer
      Thank you
      Ivonne
      • waqas99
        Hi Ivonne,
        I have studied that workshop and as a matter of fact, my design is based on that particular workshop from #ANSYS.
        I have selected the Dynamic Eddy current compnent. I wonder, if it would be possible to upload my Twin Builder file here so you guys can help.
        Best,
        Waqas
    • GLUO
      Could you try debug the circuit and ROM on by one? Like using a simple circuit and see if the ROM works first.
      GL
      • waqas99
        Hi GLUO,
        Would it be possible to upload my #TwinBuilder file here, so you guys can help. I have tried your proposed solution, but no luck!
        Best,
        Waqas
    • GLUO
      Hi Waqas,
      You could use the support button at left to submit a ticket and upload the files.
      GL
      • waqas99
        I am using a student version, I tried to upload the files but I need customer number.
    • truong15 king
      hi everyone, i have a question. How can i create another output (exp: Fore ) in maxwell to simplorer
      • GLUO
        You can double click the Maxwell block and check "Show Pin" for other outputs.
        GL
    • waqas99
      Dont bother asking, there is almost no support from ANSYS staff.
      • GLUO
        This is more a user helps user forum on general questions. For direct support on specific project, please contact the account manager of your organization for your account number and submit a case ticket.
        GL
Viewing 5 reply threads
