TAGGED: ansys-twin-builder, noise-generation, twin-builder
January 30, 2021 at 4:50 pm
yannick25
SubscriberHello,ncurrently I have to simulate a setup for a differential Rogowski coil. nFor testing the noise cancelling of the the instrumental amplifier I am searching for an option to generate noise. I only found the option to generate noise at the supply voltage of the op amp, but not a way to add noise on my test signal.Thanks in advanced !nBest regards, nYannickn -
February 2, 2021 at 3:02 pm
Jose Luis Gonzalez Hernandez
Ansys EmployeeHello Yannick,nnYou can add noise to your test signal by creating a Modelica model and using one of the noise components there. You can find documentation on Modelica models in the Twin Builder help pdfs and also in the examples folder. The Ansys Learning Hub (Twin Builder Room) has three modules (7-9) to get you started on Modelica models.nnThank younnJose-Luis
- Changing of font size
- System Coupling
- 3D ROM in workbench
- ANSYS Workbench Mechanical Solver problem after saving
- ansys with matlab
- Error message “Solver pivot warning” due to element birth and death
- HARDWARE COMPATIBILITY
- System Coupling
- ANSYS Direct Optimization
- When I open the Electronic Desktop, Twin Builder auto opens
5242
3299
2469
