April 26, 2022 at 10:22 am
apoynter1
SubscriberHi,
I am simulating the final stage of an MQW laser in Interconnect to output the LI curves. However, I want to include losses due to free carrier absorption in doped cladding layers. How do I define the doped cladding layers such that this coefficient can be multiplied by the dopant carrier density such that the loses can be calculated. In addition the laser appears to be simulating with sufficient gain from MQW yet the LI curve suggests that the laser does not lase.
April 27, 2022 at 10:19 pmGuanhui Wang
Ansys EmployeeHi alfapoy TWLM has two optical loss options: "loss" and "loss density coefficient". "loss" is for constant loss (independent of density) and "loss density coefficient" is for loss that depends on the quantum well density. If the doping density is constant you can just use "loss" but first you need to calculate the optical loss (e.g. using MODE with some FCA model).
April 27, 2022 at 10:45 pmapoynter1
SubscriberThank you for the reply. As MODE does not allow for doped materials(which my cladding layers are), how might loss through free carrier absorption be calculated in MODE, the documentation for MQW Edge Emitting laser eludes to this however I am unsure on how? The confinement factor for the model has been simulated in MODE and parsed into MQW for then simulating in INTERCONNECT, as per the example. However I am unsure on which loss mechanisms are accounted for in this example as the dopant levels of layers cannot be defined for free carrier absorption calculations. Does MODE have an alternate way of calculating these values to then be parsed into the TWLM simulation?
Viewing 2 reply threads- The topic ‘TWLM loss density coefficient’ is closed to new replies.
Trending discussions- Ansys Insight: About override mesh in FDTD: its use and settings
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
