December 26, 2022 at 5:51 pm
Yahya Alkaisi
SubscriberI am trying to model a tank containing water and phase change matter. The tank is made of aluminium. The tank contains water. Inside the water there are aluminum containers. The containers contain the phase change material. The program works normally only when the water temperature is selected. When determining the temperature of the phase change material, a floating point appears.
How can both the temperature of water and a phase change substance be determined?! -
December 28, 2022 at 5:09 am
Nikhil Narale
Ansys EmployeeHello,
"The program works normally only when the water temperature is selected. "
Can you please elaborate on this?
"How can both the temperature of water and a phase change substance be determined?!"
Is this about post-processing? I doubt that. Post-processing shouldn't have any influence on the solution.
Can you share some screenshots and more provide details?
Thanks!
Nikhil
2630
2104
1329
1110
461
