November 9, 2018 at 8:48 pm
pawar002
SubscriberI am running a simulation on the cluster, I have observed that at the time of initialization, patched zones were showing correctly in contours. but after running a certain time step. I am getting wrong results. patched zones got merged. Is it because of parallel processing?
November 10, 2018 at 9:10 am
DrAmine
Ansys EmployeeNo. It has nothing to do with parallel. Are the zones separated through walls or interior. If interiors thenwhat you see is due to you have mixing, diffusion and buoyancy.
What do u want to do?
November 12, 2018 at 6:15 am
seeta gunti
Ansys EmployeeHello,
It is not necessary to be apart throughout the solution after the patching the zones with two different fluids. Patching is a different kind of initialization but not a source where it remains constant throughout the solution. When the solution progresses two fluids can mix/merge due to mixing ( flow conditions).
Seeta
November 12, 2018 at 7:32 am
Keyur Kanade
Ansys EmployeeAs Amine has mentioned, if its interior between two zones, then what you see is correct.
if you want them as different zones then you can decompose geometry in spaceclaim and define named selection to that common face and then use wall boundary condition.
November 12, 2018 at 3:52 pm
pawar002
SubscriberThank you so much abenhadi, seeta gunti and kkanade. I am working on it i will update you soon.
2656
2120
1347
1118
461
