November 3, 2018 at 8:43 am
November 3, 2018 at 12:21 pm
mchristi
Ansys EmployeeThis can be simulated in the Maxwell Eddy Current solver by first creating three windings with type "external" and then connecting them in series/parallel (as shown in your schematic) using the and external circuit editor. Please reference online help topic: "Setting Up an External Circuit Using the Maxwell Circuit Editor".
March 27, 2019 at 12:03 pm
Radian
SubscriberKindly help to get the External Ciruit editor launched in Maxwell 18.1
I created a new transient design and the editor will not launch or show in the project manager tree after I have created windings and then hit EDIT EXTERNAL CIRCUIT.
I have done this many times in V16 but now the circuit editor seems to be not independant anymore .
To go forward I imported a netlist sph file which I had previously created. That worked but still I cannot get into editing that circuit or the new project circuit.
May 10, 2019 at 6:18 pm
xzhao
Ansys EmployeeMaxwell Circuit editor can be launched by using the shortcut on the command bar - Desktop - Maxwell - Maxwell Circuit (screen capture below). A netlist is the script representation of a circuit design. Using a circuit design can create a netlist file while a circuit design cannot be automatically recreated by its netlist.
- Maxwell, HFSS or Q3D?
- Error
2524
2064
1279
1096
456
