Two phase flow in Flunet with RGP table
    • abbas
      I want to use the RGP table for two-phase CO2 simulation in the tube. I generated the RGP table and import the table in the Fluent by Table file manger. When I choose the two-phase option on (VOF) and energy on, Fluent will close itself by giving the following error.
      Could you help me?
      Best regards
      Abbas
    • DrAmine
      Which version?
    • abbas
      Hello Amine,
      ANSYS 2020 R1
      Best regards
      Abbas
    • DrAmine
      I need to check that.
    • abbas
      Do you think, it's a problem related to the FLUENT? Because I have done two-phase flow simulation in CFX with the RGP table.
      Best regards,
      Abbas
    • DrAmine
      Yes I think it is related to Fluent. As I said I will update whenever I have something to share. Thanks for patience.
    • DrAmine
      The problem is now fixed. The fix will be available within the next version.
Viewing 6 reply threads
