Two Phase LES
    • Gorilla Koala
      Can ANSYS fluent calculate two phase (water-sand) LES?
      Thanks!!
      Yes.
    • Gorilla Koala
      I see. I would like to calculate effect of particle flow on the turbulence of fluid. Eventually I wanna calculate acoustic pressure generated by the turbulence. Would you tell me which calculation method I should use? Are there any instruction page to calculate two-phase (liquid-solid) LES?
      Have a look in the manuals for Mixture Model (multiphase), focus on granular, and LES (turbulence). The courses under Learning (book icon on the left hand tool bar here) will cover some of the basics and specifics. Depending on the detail you need you may find it's an excessively computationally expensive calculations.
    • Gorilla Koala
      I see. Thank you so much for the clarification.
Viewing 4 reply threads
