April 24, 2023 at 5:24 am
Chinmaya Kumar Patra
SubscriberI am doing a conjugate two phase simulation. I am not using turbulent model and my complete flow domain is laminar. I am refining the mesh for fluid but what is long-wall type of mesh (suggested by Ansys)?
April 24, 2023 at 7:58 am
Ansys EmployeeGiven your other questions (always post a set of questions into one thread) you need to read the boiling model background.
- What is the difference between internal and external flows?
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- How do you define specific gravity? What is its significance???
- The level of water inside the straw was higher than the level of water in the beaker
- Why does the total sum of forces acting on a system always have to be equal to zero?
- What is the surface tension of a fluid?
- Cell Counting?
- Explain Bernoulli’s principle
- Whats the difference between sensible heat and latent heat?
- How to gain research experience?
5162
3273
2445
