November 18, 2022 at 10:29 am
Dario De Domenico
SubscriberI would like to import in turbogrid a two-stage pump file. The problem is that when I try to import the file profile.curve I can see only either the blades of the first impeller or the blades of the second one and this is not easy and this gives me problem when I try to mesh the domain. Is there a way to show them both?
November 30, 2022 at 6:37 am
Akshay Gedam
SubscriberTurboGrid can only mesh one blade passage/stage at a time. You will need to split the profile.curve file into separate files for each stage. Then you can generate a mesh for each stage. You will need to set the inlet passage interface of the second stage to the same position as the outlet passage interface of the first stage.
Hope this helps to solve your quiry.
Thank you!
- Using GPU in FLUENT
8786
4658
3151
1680
1468
