TAGGED: fluent, fluent-post-processing, two-way-coupling
April 29, 2022 at 12:10 pm
AhmetBerkay
SubscriberI did two way FSI for the aircraft wing structure , I can examine the mechanical results. However, cannot see the fluent results in both fluent module and post processing module(PST), I have the .h5 and .dat files from the result but not able to post process.
How can should I use my files?
May 6, 2022 at 5:55 pmStephen Orlando
Ansys EmployeeWhat happens when you try to post-process the Fluent results in Fluent? Is there an error message? Please include screenshots to describe exactly what you're seeing.
June 1, 2022 at 8:57 amAhmetBerkay
SubscriberWhen i tried to export fluent solution data as ensight case gold, i got error as "x-velocity data not available".
3850
2629
1853
1252
600
