December 14, 2022 at 2:53 pm
valentin miguel
SubscriberHello,
In my projet have big error of Type. For example :
TypeError: expected IDesignBody, got DesignBody
TypeError: expected ISelection, got Selection
In a document API_Scripting_Class_Library.chm in C:\Program Files\ANSYS Inc\v222\scdm\SpaceClaim.Api.V22, ISelection is interface, but I don't know use it.
For instance, function "SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.BodyExtrema(selection_example).X" need as input a ISelection (selection_example) and have for ouput a float
What is a right code for selection_example is a ISelection ? Or how to change Selection type to ISelection type?
thanks for the help
Miguel Valentin
December 19, 2022 at 2:39 pm
Aniket
Ansys EmployeeCan you please give some more information about this error? At which line do you get this? Are you using a recorded script?
-Aniket
December 22, 2022 at 6:04 pm
valentin miguel
SubscriberI use recorded script but i modifided it for create a wizard.
My code :
import Systemimport clrimport sysimport osimport mathimport zipimportimport __builtin__import commandsimport random"""'SpaceClaim':, , 'Commands':, 'System':, """clr.AddReference("SpaceClaim.Api.V22")clr.AddReference("SpaceClaim.Api.V22.Scripting")#clr.AddReference("AnsysSCPlugin.22.2")#from SpaceClaim.Api.V22 import Geometry#from SpaceClaim.Api.V22.Scripting import Commands,Helpers,Selection#from AnsysSCPlugin import *from SpaceClaim.Api.V22 import *from SpaceClaim.Api.V22.Scripting import *from System import *part = Nonedef oninit(context):returndef GenerateBF(step):global partwin = Window.ActiveWindowcontext = win.ActiveContextpart = context.ActivePartif part==None:win = Window.ActiveWindowcontext = win.ActiveContextpart = context.ActivePart.Masterbody = part.Bodies#verifier le measurehelper#--------- selection--------------ExtAPI.Log.WriteWarning("TENTATIVE 2")#body = GetRootPart().Bodies[0]#se = Selection.Create(body)#se = Selection.Create(GetRootPart().Bodies[0])#se = PowerSelection.Bodies.AllSolidBodies(PowerSelectOptions(False))#se = Selection.SelectAll()#se = SpaceClaim.Api.V22.Scripting.Selection.ISelection.FilterByVisible#---------------------------------- attempt 1#X = Direction.DirX#Y = Direction.DirY#Z = Direction.DirZ#XMIN = se.GetExtremePoint(-X,Y,Z)#XMAX =se.GetExtremePoint(X,Y,Z)#YMIN = se.GetExtremePoint(-Y,Z,X)#YMAX =se.GetExtremePoint(Y,Z,X)#ZMIN = se.GetExtremePoint(-Z,X,Y)#ZMAX =se.GetExtremePoint(Z,X,Y)#xOverall = abs(XMAX[0]-XMIN[0])#yOverall = abs(YMAX[1]-YMIN[1])#zOverall = abs(ZMAX[2]-ZMIN[2])#----------------------------------- attempt 2#bb = Selection.Create(GetRootPart().Bodies[0])#MAX = bb.BoundingBox.MaxCorner##MIN = bb.BoundingBox.MinCorner#xOverall = abs(MAX[0]-MIN[0])#yOverall = abs(MAX[1]-MIN[1])#zOverall = abs(MAX[2]-MIN[2])#-------------------------------------attempt 3#centre = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.GetCenterOfMass(se)#rX = Direction.DirX#ms = MeasureHelper.BodyExtrema(se).X#bb = SpaceClaim.Api.V22.Scripting.Selection.ISelection.AddToActive(Selection.Create(GetRootPart().Bodies[0]))#rr = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper()#cvd=rr.BodyExtrema(bb)selection = SpaceClaim.Api.V22.Scripting.Selection.BodySelection.Create(GetRootPart().Bodies[0])#selection = SpaceClaim.Api.V22.Scripting.Selection.ISelection.SetActive(SpaceClaim.Api.V22.Scripting.Selection.ISelection)#selection = SpaceClaim.Api.V22.Scripting.Selection.xOverall = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.BodyExtrema(selection).X#sele = PartSelection.Create(GetRootPart())#sele = GetRootPart().Bodies[0]part = NoneThere are error on "xOverall=SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.BodyExtrema(selection).X"
"selection" is not right, we need an "ISelection" type and we have the "Selection" type. I can't use the "MeasureHelper.BodyExtrema()" function, when I use it in Wizard.
Thank you
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
