UDF 3D Rotation for Fluid in concentric sphere
    • AndyHor
      Hi everyone,
      I am first time user to UDF, and using ansys 2016.
      I am trying to put expressions for a 3D , 1/8 concentric sphere, and the fluid is driven by lower surface to oscillate with respect to z-axis. Two pictures is shown in below for better view.
      In 2019 version, i can put the boundary conditions as expression as sin(t/1)*1[rad/s] for the lower oscillating surface.
      If I want to write in UDF, can I write in this way ? Please advise.
        oscillatingwall.c
        UDF for specifying a transient simple harmonic motion
      #include "udf.h"
      #define angular_freq 1
      DEFINE_GRID_MOTION(inneroscillatingwall, dt, cg_vel, cg_omega, time, dtime)
         Thread*t; /*is the pointer to the structure that store*/
         real omega;
         /* reset velocities */
         NV_S (vel, =, 0.0);
         NV_S (omega, =, 0.0);
        t=DT_THREAD(dt); /*Get the tread pointer for which this motion is defined*/
         omega = sin(angular_freq*time); /*rotional speed about axis*/
         cg_vel[0] = 0.0; /*x y z translation*/
         cg_vel[1] = 0.0;
         cg_vel[2] = 0.0;
         cg_omega[0]=0.0;  /* x y z rotational axis*/
         cg_omega[1]=0.0;
         cg_omega[2]=omega;
    • AndyHor
      I have tried several methods, and amended some code, this is what I currently facing, could anyone please help ?
      #include "udf.h"
      #define angular_freq 1.0
      DEFINE_CG_MOTION(inneroscillatingwall, dt, cg_vel, cg_omega, time, dtime)
      real omega;
      cg_vel[1] = 0.0;
      cg_vel[2] = 0.0;
      cg_omega[1]=0.0;
      cg_omega[2]=omega;
      /*When I press build button, it gives */
      Setting Post Processing and Surfaces information ... Done.
      Copied C:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluent/C:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentUDF oscillating.c to libudfsrc
      Creating user_nt.udf file for 3ddp ...
      (system "copy "C:PROGRA~1ANSYSI~1v170fluent"fluent17.0.0srcudfmakefile_nt.udf "libudfwin643ddpmakefile" ")
      1 file(s) copied.
      (chdir "libudf")(chdir "win643ddp")'nmake' is not recognized as an internal or external command,
      operable program or batch file.
      Done.
      /*When I press load button, it gives*/
      Opening library "C:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentC:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentlibudf"...RPC RCX_SC_SET_ERR_MSG failed: RPC: Can't encode arguments
      Error: The UDF library you are trying to load (C:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentlibudf) is not compiled for 3ddp on the current platform (win64).
      The system cannot find the file specified.
      C:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentC:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentlibudfwin643ddplibudf.dll
      Error: The UDF library you are trying to load (C:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentlibudf) is not compiled for 3ddp on the current platform (win64).nnThe system cannot find the file specified.
      nnC:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentC:UsersDell T7600DesktopChee Hao AnsysHip Gap_filesdp0FFFFluentlibudfwin643ddplibudf.dll
      Error Object: #f
      /*And then I restart Ansys, it somehow have the UDF file, when I load to the boundary, and press ok, it gives */
      Error: received a fatal signal (Segmentation fault).
      Error Object: #f
