Tagged: ansys-fluent, boundary-conditions, udf, udf-fluent
March 21, 2022 at 2:04 pm
isaps1860
SubscriberI have written an UDF for Calculating the area of a surface. The UDF works perfect for the surface of an inlet or an outlet, but for an interior surface the values are wrong. A test example for a simple tube gives different results for inlet and interior surfaces although the areas should be identical.
Is there anything additional to consider for the calculations of the areas for interior?
UDF is below:
#include "udf.h"
DEFINE_ADJUST(Face_area1, domain)
face_t face;
Thread* thread;
domain = Get_Domain(1);
int zone_id = 35;
thread = Lookup_Thread(domain, zone_id);
real NV_VEC(va); /* for storing area vector */
real Area = 0;
begin_f_loop(face, thread)
F_AREA(va, face, thread); /* Obtain the area vector */
Area += NV_MAG(va); /* Obtain area magnitude */
end_f_loop(face, thread)
#if RP_NODE
Area = PRF_GRSUM1(Area);
#endif
node_to_host_real_1(Area);
#if RP_HOST
Message("Area of surface1 is %e ", Area);
#endif
Best regards
March 21, 2022 at 5:26 pmRob
Ansys EmployeeTry summing the modulus of the area. Interiors don't have an aligned surface normal. It's why the Flux Reports don't pick up the interior faces.
March 21, 2022 at 5:40 pmisaps1860
SubscriberThank you for your answer . Makes sense, that with no aligned surface normal there is no logical result.
But I have to ask what do you mean with "summing the modulus of the area"? Don┬┤t really understand that.
March 21, 2022 at 6:18 pmDrAmine
Ansys EmployeeLook in the documentation you will see that on interior bcs not all variables are available and that you require other connectivity macro
March 22, 2022 at 10:53 amRob
Ansys EmployeeIf the vector is random you may find the x-area to be positive or negative: hence sum the modulus (positive) values.
Viewing 4 reply threads- You must be logged in to reply to this topic.
2688
2138
1355
1140
462
