July 31, 2018 at 5:32 pm
nickgaoda
SubscriberI want to calculate the time dependent velocity gradient (G) based on the turbulent kinetic energy and dissipation rate, but I am not sure how to call values of turbulent kinetic energy and dissipation rate from prior time step. From the UDF manual, only the density, velocity, temperature and species mass fraction from previous time step can be called by the macro. Is there anyone knows how to solve it? Thank you.
August 1, 2018 at 1:38 am
August 1, 2018 at 6:23 pm
August 2, 2018 at 1:55 am
Karthik R
AdministratorHello You can use DEFINE_ADJUST macro, which is executed at the beginning of each time-step. If you are storing values using C_D(c,t) into a UDM, it would read the cell values which are from previous time-step.
Hope this helps.
Best Regards Karthik -
August 2, 2018 at 4:29 pm
nickgaoda
SubscriberThat works! Thanks your very much
2522
2064
1279
1094
456
