UDF-code
    • Abbas2020
      HinHow can I write a UDF-code for inlet temperature( fully developed profile) with conjugate heat analysis? I have two inlets ( two fluid domains and solid domain).nAlso, how can I write a code for velocity and k-e profiles, by making a fully developed flow at inlet with copying the face mesh of outlet profile to inlet?.nBest regardsnA.An
    • DrAmine
      Please check the manual for DEFINE_PROFILE examples. Better to use Fluent Expression (example in the User'Guide to code a parabolic velocity profile)n
    • Abbas2020
      Thanks for your reply,nI have checked the manual, but no thing is helpful. The geometry is non-circular pipe. Perhaps, the velocity profile is not complicated. However, the periodic temperature profile for both inlets( for each fluid) is complicated since I am doing conjugate heat analysis between two fluids and interface solid domain. n
    • Karthik R
      Administrator
      If you are looking for these detailed profile files, I'd say run a quick simulation with streamwise periodic flow conditions. This will give you the necessary profiles which you can use in your final simulation.nThanks.nKarthikn
    • Abbas2020
      Thanks Kremella for your reply.nYour way can be done for velocity field or pressure, but how about the temperaure?n
    • Abbas2020
      You can see in the attached for what I am talking about. I have a counter flow between two fluids which are separated by a wall (solid domain). I'm trying to write a UDF , in which I am coping the velocity of the outlet face to inlet. But I got more problem in that code.nSo, I am looking for better way to solve this problem. or how I can copy the velocity at outlet face to inlet to make as periodic. Another issue is with Temerature.nnBest regards.nAbbasnn
      For velocity you can use a profile. If you fix the temperature in that way you'll find both sides have the same value as you'll be modelling the equilibrium condition. n
    • Abbas2020
      Thanks Rob for your reply,nThe wall temperature is variant linearly. It is not constant. If it is constant, then it is easy to model the problem as separated domains.nCan I apply a periodic(UDF) temperature on both ends for each fluid?.nRegardsnAbbasn
      You can, but think through the temperature field. If in=out on both sides what temperature will that become? n
    • Abbas2020
      Yes, you are right. but I think to apply a temperature profile at the inlets instead of periodic temperature. n
      OK, so you can use a profile. But, you'll still need to figure out at what value. n
Viewing 10 reply threads
