August 13, 2018 at 12:59 pm
u_tozar
SubscriberHi all,
I have a problem which relating with UDF compiler in Fluent. Whenever, I attempt to load udf through visual studio 13.0, it says c++ compiler has stopped working. How can I solve this problem?
p.s. I have attached a screenshot file.
August 13, 2018 at 5:30 pm
ANSYS_MMadore
Ansys EmployeeHello,
Have you tried using a newer version of Visual Studio? Please ensure the 64 bit C++ compiler is installed, you can check this usually through a "modify" of the installation of Visual Studio.
Please make sure your PATH environment doesn't contain conflicting paths for versions of visual studio.
Thank you,
Matt
- Workbench error
- Workbench not opening
- License Error
2706
2146
1357
1144
462
