October 8, 2023 at 2:51 am
joce0001
SubscriberI have a fluid whose temperature varies depending on the height, I have made the UDF, I have compiled, but I do not know how to enter this UDF as an initial condition, because in the Solution Initialization section there is no way to select UDF.
The UDF programming is as follows
#include "udf.h"
DEFINE_INIT(temperatura_profundidad, domain)
cell_t cell;
Thread *thread;
real x[ND_ND]; /* Vector de posición */
real profundidad;
real temperatura;/* Loop sobre todas las celdas en el dominio */
thread_loop_c(thread, domain)
begin_c_loop(cell, thread)
C_CENTROID(x, cell, thread); /* Obtener las coordenadas del centroide de la celda */
profundidad = x[1]; /* Asumiendo que la coordenada y representa la profundidad */
temperatura = -7.1 * profundidad + 298; /* Aplicar la fórmula de temperatura en función de la profundidad */
C_T(cell, thread) = temperatura; /* Definir la temperatura de la celda */
end_c_loop(cell, thread)
October 9, 2023 at 9:05 am
Forum Moderatorhttps://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/flu_udf/flu_udf_ActivatingGeneralSolverUDFs.html%23flu_udf_sec_use_init
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
