August 30, 2022 at 11:51 am
mardott
SubscriberHello 🙂
I want to assign a temperature dependent heat capacity to my DPM particles.
I've therefore been trying with the following UDF:
DEFINE_DPM_PROPERTY(DPMaterial_Cp, c, t, tp, T)
#if !RP_HOST
real Cp; /* Heat Capacity - Cp J/(kgK) */
if (NULLP(tp->pp) || NULLP(TP_CELL_THREAD(tp)))
Cp = 320; /* J/(kgK) initial value for T = 1100 */
else
Cp = 450.60 - 116.10*pow(10.,-3.)*T - 166.79*pow(10.,5.)*pow(T,-2.);
tp->enthalpy = Cp * (T - T_REF);
return Cp;
#endif
THe UDF compiles, and the DPM iterates for a few times, but then the simulation crashes (only when this UDF is implemented).
What am I doing wrong? -
August 30, 2022 at 3:55 pm
Ansys EmployeeCheck the value of cp that's being returned for the temperature range in your model. Plot cp with T using the above relationship, how does it look?
August 30, 2022 at 4:15 pm
mardott
SubscriberSo, what I've noticed is that, for some reason, my DPM temperature becomes unphysically low in few points:
This happens even if the flow temperature makes sense
Leading to what it probably is the cause of the crash: a negative Cp (but for the range of T that I should have it would surely be positve)
The question now is: how is it possible that my particles get such a low temperature in some sparse points?
August 31, 2022 at 2:34 pm
Ansys EmployeeDepending on the mass of the parcel and cell size if you evaporate quickly the DPM source terms can become high, and that can cause problems with the flow (cell) values. How many parcels are you releasing, and how does the mass (and volume) fraction look?
2630
2104
1327
1110
461
