December 15, 2022 at 3:57 pm
Ahmad Hadi Bakir
SubscriberI am using Fluent 2021 R2 on a Red hat linux cluster to run a 2D transient flame simulation. The purpose of this work is to investigate the effects of heat loss on the flame using the Planck Mean Absorption coefficients as a function of temperature for H2O, CO, CO2, and CH4. I created a UDF that calculated this absorption coefficient looping for each cell in the simulation.The UDF source code is shown at the bottom. I am first attempting to check the UDF on a Windows 11 computer to see its validity before applying it to the cluster. The issue I am having is when I try loading the UDF after building it, it gives me Error athost: Error code: 126. Could you please help me resolve this issue? Thank you in advance.#include "udf.h"
DEFINE_GRAY_BAND_ABS_COEFF(user_gray_band_abs,c,t, nb)
Domain *domain;
Material *m = THREAD_MATERIAL(t);
int ico2 = mixture_specie_index(m, "co2");
int ico = mixture_specie_index(m, "co");
int ih2o = mixture_specie_index(m, "h2o");
int ich4 = mixture_specie_index(m, "ch4");
thread_loop_c(t, domain)
cell_t c;
begin_c_loop(c, t) /* loops over cells in a cell thread */
real CO2_molf, CO_molf, H2O_molf, CH4_molf;
real a_co2, a_co, a_h2o, a_ch4;
real abs_coeff = 0;
real T = C_T(c, t);
real P = C_P(c, t);
CO2_molf= (C_R(c, t) * C_VOLUME(c, t) * C_YI(c, t, ico2))/44.01;
CO_molf = (C_R(c, t) * C_VOLUME(c, t) * C_YI(c, t, ico))/28.01;
H2O_molf= (C_R(c, t) * C_VOLUME(c, t) * C_YI(c, t, ih2o))/18.01528;
CH4_molf= (C_R(c, t) * C_VOLUME(c, t) * C_YI(c, t, ich4))/16.04;
a_h2o = -1.40598 + (5.1403E+3 / pow(T,1)) + (-2.49209E+6 / pow(T,2)) + (5.87875E+9 / pow(T,3)) + (-2.33462E+12 / pow(T,4)) + (3.28929E+14 / pow(T,5));if((300<=T) && (T<=865))
a_co = 3.32332E+1 + (-3.81859E-1 * pow(T,1)) + (1.68054E-3 * pow(T,2)) + (-3.59221E-6 * pow(T,3)) + (4.10932E-9 * pow(T,4)) + (-2.44251E-12 * pow(T,5)) + (5.96159E-16 * pow(T,6));
else if(865<=T)
a_co = 1.14597 + (2.32393E-2 * pow(T,1)) + (-5.17447E-5 * pow(T,2)) + (4.65068E-8 * pow(T,3)) + (-2.13393E-11 * pow(T,4)) + (4.97086E-15 * pow(T,5)) + (-4.67667E-19 * pow(T,6));
if ((300<=T) && (T<=860))
a_co2 = -1.61017E+2 + (2.07661 * pow(T,1)) + (-1.00536E-2 * pow(T,2)) + (2.58277E-5 * pow(T,3)) + (-3.59098E-8 * pow(T,4)) + (2.54860E-11 * pow(T,5)) + (-7.25425E-15 * pow(T,6));
else if(860<=T)
a_co2 = -8.16334 + (2.72779E-1 * pow(T,1)) + (-5.37382E-4 * pow(T,2)) + (4.56021E-7 * pow(T,3)) + (-2.01261E-10 * pow(T,4)) + (4.54957E-14 * pow(T,5)) + (-4.17609E-18 * pow(T,6));
if ((300<=T) && (T<=645))
a_ch4 = 9.34245E+1 + (-1.36727 * pow(T,1)) + (8.19456E-3 * pow(T,2)) + (-2.49120E-5 * pow(T,3)) + (4.11322E-8 * pow(T,4)) + (-3.53140E-11 * pow(T,5)) + (1.23840E-14 * pow(T,6));
else if(645<=T)
a_ch4 = -6.04867 + (6.35149E-2 * pow(T,1)) + (-1.29462E-4 * pow(T,2)) + (1.17164E-7 * pow(T,3)) + (-5.49038E-11 * pow(T,4)) + (1.30767E-14 * pow(T,5)) + (-1.25597E-18 * pow(T,6));
C_ABS_COEFF(c,t) = ((P / 101325)*((a_h2o * H2O_molf) + (a_co * CO_molf) + (a_co2 * CO2_molf) + (a_ch4 * CH4_molf)));return C_ABS_COEFF(c, t);
end_c_loop(c, t)}
December 15, 2022 at 4:20 pm
Ansys EmployeeCan you check the code compiled? A quick search for "error code 126" on here shows it's possible it hasn't. Note, use the included compiler on Win11 do NOT leave that option selected for Linux.
2706
2146
1357
1144
462
