UDF error on linux
    • soloviev
      I am trying to compile a UDF on linux and when I do it gives me the following error:
      The UDF library you are trying to load (libudflinux) is not compiled for parallel use on the current platform (lnamd64).
      No such file or directory
      /home/bv169/simulations/gradient_adaption/libudflinux/lnamd64/3ddp_host/libudf.so
      I have run UDF's on this same machine previously and did not have this issue. The computer was able to generate the libudf.so file fine.
      Thanks,
      Alex
    • DrAmine
      are u able to compile a dummy UDF?
    • soloviev
      I have other UDFs that I can try to compile. They have worked in the past on the same machine. I will update after I try to compile a different UDF.
    • soloviev
      I tried another UDF and it compiled without error.
      Thanks,
      Alex
    • DrAmine
      Can you try compiling in new Fluent session before loading any case file?
    • soloviev
      It did not work. I realized that the commenting out of the text in the UDF was in windows format and it needed to be changed to linux format.
      Thank you.
      Alex
Viewing 5 reply threads
