November 14, 2020 at 1:38 pm
JD_JN
SubscriberHello,
I have created a UDF for initialization of flow properties.
The UDF builds and loads correctly, and I am able to hook it for initialization.
However after when I select "initialize" (standard or hybrid) FLUENT (19R2) throws this error:
November 14, 2020 at 1:39 pmJD_JN
SubscriberI had also provided values for User defined memory locations and that doesn't help eithernNovember 16, 2020 at 12:11 pmDrAmine
Ansys EmployeeCan make a screenshot of the UDF? nNovember 16, 2020 at 12:20 pmRob
Forum ModeratorTry and initialise without the UDF and then use the UDF. It's possible you are trying to call values that don't exist (eg position) without a more general initialisation. nJuly 22, 2022 at 2:00 pmJuly 22, 2022 at 2:02 pmirfan.sc19b048
SubscriberSome body please help me out.
July 22, 2022 at 2:42 pmRob
Forum ModeratorMake the mass return a constant, does that work?Â
July 23, 2022 at 6:04 pmirfan.sc19b048
SubscriberI tried with this still getting the same error
Viewing 7 reply threads- The topic ‘UDF Error when initialization (Standard or Hyrbid)’ is closed to new replies.
Trending discussions- Floating point exception in Fluent
- Using GPU in FLUENT
8808
4658
3151
1680
1470
