UDF execution problem in Porous media tutorial of FLUENT
    • vinaychandrakar11
      Hi Everyone,
      I am trying to simulate the 2D (planar) domain consists of a 90-degree bend. The duct has a porous region covers the bottom and right-hand wall, and the reaction takes place in the porous region only.
      This problem is from the FLUENT UDF tutorial . link for the problem is given below.
      https://www.afs.enea.it/project/neptunius/docs/fluent/html/udf/node246.htm
      Code for reaction rate mentioned in the tutorial is
      rate.c
      Compiled UDF for specifying a reaction rate in a porous medium
      #include "udf.h"
      #define K1 2.0e-2
      #define K2 5.
      DEFINE_VR_RATE(vol_reac_rate,c,t,r,mole_weight,species_mf,rate,rr_t)
        real s1 = species_mf[0];
        real mw1 = mole_weight[0];
        if (FLUID_THREAD_P(t) && THREAD_VAR(t).fluid.porous)
          *rate = K1*s1/pow((1.+K2*s1),2.0)/mw1;
        else
          *rate = 0.;
        *rr_t = *rate;
      My problem is that I am not able to compile this code and its showing error in the line shown below.
      As per the problem shown in the tutorial, reaction happens only in the porous zone and above line which is showing error makes sure that its taking porous domain only. But I am not getting why its showing error in this line.
      Can anyone help me with this?
      Thanks in Advance.
    • DrAmine
      Error message?
    • vinaychandrakar11
      Its showing that "structure reference not implemented". (for "interpreted" option)
      After that I tried to "compile" it but its showing below mentioned error
      and when I used "built in compiler" , its showing that ud._iol.h file not found.
    • vinaychandrakar11
      Hi Everyone, Problem is resolved now. There are two problems.
      1) It reads only ".c" File not ".C" file.
      2) I am able to compile the UDF with command prompt in my windows system. But unable to do it directly.
    • DrAmine
      Try compiling a dummy Hello World UDF (DEFINE_ON_DEMAND) without reading any Fluent case file.
Viewing 4 reply threads
