May 8, 2023 at 11:23 pm
mctom0518
SubscriberI am new to defining UDFs for adjacent cells. I am dealing with a system that requires transferring data from one boundary to the adjacent boundary along an internal-internal boundary. The problem is that I am dealing with 3 internal boundaries that are adjacent to one another (e.g. water internal boundary, equilibrium internal boundary as a thin surface, and gas internal boundary). I wish to collect adjacent cells of the "equilibrium boundary layer" but only in the "gas internal boundary layer."
Is there a way to select adjacent cells only from one domain (as opposed to adjacent cell)?
May 9, 2023 at 10:02 am
Ansys EmployeePlease can you post an image? I'm not quite sure what you're trying to do.
May 9, 2023 at 5:02 pm
May 10, 2023 at 10:06 am
Ansys EmployeeIs that a mesh boundary or a liquid free surface?
May 10, 2023 at 3:47 pm
mctom0518
SubscriberHello Rob,
This is a mesh boundary.
May 10, 2023 at 4:03 pm
Ansys EmployeeIf it's a wall & wall:shadow there should only be one cell for each surface facet. Where that surface contacts the external wall gets messy as the cell may not be common to both boundaries.
May 10, 2023 at 4:07 pm
mctom0518
Thank you for your reply. Actually, all of these zones are internal, which is why I am confused about how to select the correct adjacent cells.
Is there a way that I can use an "IF" loop to only perform operations on cells for specific z-coordinate?
e.g. IF z >= 1 do .... else z <= 1 do nothing
May 10, 2023 at 4:21 pm
Ansys EmployeeThat could work. You're looking for the cell is a specific cell zone assuming you have two or three different fluid zones (labels).
May 10, 2023 at 4:25 pm
mctom0518
SubscriberYes, that is correct. Would I be able to use something like C_CENTROID for the z-axis only, while also using F_C0 and F_C1?
May 11, 2023 at 11:11 am
Ansys EmployeeIt could, but what happens when the surface moves due to the flow solution?
5290
3299
2469
