January 30, 2018 at 11:38 am
saadyw
SubscriberI have a 2D dynamic mesh case of a piston-cylinder arrangement as attached. I can create a udf to move the piston under certain velocity and the simulation proceeds with no problems.
What I need is to set the dynamic mesh zones according to a udf expressing the equation of motion of the piston which is :
a = (F + p1*A1 - p2*A2) / m or if represented with velocity dv = (F + p1*A1 - p2*A2) * dt / m
where: a .. acceleration, F .. External force, p1,p2 .. pressures on upper and lower piston boundaries respectively, A1,A2 .. areas at same locations and m .. mass of the piston.
I have got through a similar udf in the udf manual for equation of motion in x-dir, but I do not understand how the pressure forces are computed. So, I want to know how the pressure on both sides is represented in the udf in my case.
This udf link is: https://www.cfd-online.com/Forums/fluent/87021-code-dynamic-meshing-udf.html
Can you help me on this udf ?
2656
2120
1347
1118
461
