Ansys Innovation Courses
Provide feedback or ask questions related to the Ansys Innovation Courses content
UDF for Interstitial heat transfer coefficient in non equilibrium porous media
    • Robbie Crosby
      Hello, I am trying to create a UDF to fit a numerical model which must be applied as UDFs in ANSYS Fluent to model a phase change material in a porous medium. I have attached the mathematical model I am trying to follow as well as my current code. I am currently stuck on getting the interstitial heat transfer coefficient to come up as a UDF, that can be selected in ANSYS Fluent, for the non-equilibrium model of porous medium. Any help would be greatly appreciated. Should it be define_profile or define_property
      #include "udf.h"
      #include "mem.h"
      #define Tsolidus 300.0
      #define Tliquidus 304.0
      #define L_f 250 //Latent heat of fusion
      #define UDM_RHO_F_PREV 0  // UDM index for storing previous rho_f
      #define UDM_LAMBDA_PREV 1  // UDM index for storing previous lambda
      DEFINE_PROFILE(h_sfq, c, t)
          real dl, epsilon, mu, nu, pr, rho_pcm, u, v, mu_pcm, k_pcm, Re_d, h_sfq, local_h_sfq;
          cell_t cell;
          dl = 0.0194; //Diameter Matlab
          epsilon = 0.85; //Porosity Matlab
          mu = C_MU_L(c, t);        // Laminar viscosity
          rho_pcm = C_R(c, t);          // Density
          nu = mu/rho_pcm;             // Kinematic Viscosity
          pr = nu/rng_alpha(1., mu, mu); // Prandtl Number
          u = C_U(c, t);
          v = C_V(c, t);
          mu_pcm = C_MU_L(c ,t);
          k_pcm = C_K_L(c, t);
          Re_d = (rho_pcm * sqrt(u*u + v*v) *dl) / (epsilon * mu_pcm);
          if (Re_d > 0 && Re_d <= 40)
              local_h_sfq = (0.76 * pow(Re_d, 0.4) * pow(pr, 0.37) * k_pcm)/dl;
          else if (Re_d > 40 && Re_d <= 1000)
              local_h_sfq = (0.52 * pow(Re_d, 0.5) * pow(pr, 0.37) * k_pcm)/dl;
          else if (Re_d > 1000 && Re_d <= 20000)
              local_h_sfq = (0.26 * pow(Re_d, 0.6) * pow(pr, 0.37) * k_pcm)/dl;
          else
          return local_h_sfq;
    • Atharva Nagarkar
      The DEFINE_PROFILE macro is used to define a custom boundary profile or cell zone condition that varies as a function of spatial coordinates or time while you can use the DEFINE_PROPERTY to specify a custom material property in Ansys Fluent for single-phase and multiphase flows. Based on this, the DEFINE_PROPERTY macro would be more suited for your use.
      Please find the links from the Ansys UDF Manual related to both these macros. Check sections 2.3.29 and 2.3.30. I would also request you to have a look at the examples given below these sections to understand the use of these DEFINE macros.
      2.3. Model-Specific DEFINE Macros (ansys.com)
      If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
      Thanks!
