UDF for sinusoidal piston motion does not work properly
    • Muhamad Eldebawy
      Hi every body,
      I am trying to simulate the motion of piston inside cylinder. It is a sinusoidal motion
      I defined the piston as a rigid body and I wrote this UDF file to define the motion of the piston
      #include "udf.h"
      #define freq 1.5
      #define w 2.0*M_PI*freq
      #define a 0.15
      #define l 0.3
      static real velocity = 0.0;
      DEFINE_CG_MOTION(pistown, dt, vel, omega, time, dtime)
      real velocity;
      /* reset velocities */
      NV_S(vel, =, 0.0);
      NV_S(omega, =, 0.0);
      velocity = a * (w*M_PI/180) * cos(w*time);
      omega[0] = 0;
      omega[1] = 0;
      omega[2] = 0;
      vel[0] = velocity;
      vel[1] = 0;
      vel[2] = 0;
      when I display the piston motion it reciprocates and translates at the same time. It moves from point to another point and reciprocates as I defined. I do not know why it translates, it is assumed to return to its initial position ??!!
      by the way I did not define the centre of gravity (Let all values  = 0) and the global coordinates at the centre of the piston face.
      Thank you
Viewing 0 reply threads
