October 23, 2018 at 7:03 pm
maliuzair
SubscriberHi
I am simulating a three phase flow, and i want to write a udf for solid solid interaction.
SYAMLAL OBREIN SYMMETRIC DRAG MODEL
I am facing two problems.
1) when i interpret udf, it shows me undeclared variable
line 19: l_col: undeclared variable
AND
`DEFINE_EXCHANGE_PROPERTY' used with too many (6) args
2) I dont know how to include radial distribution function in the udf
Can someone please point out the flaws and how to fix them
October 23, 2018 at 7:09 pm
October 24, 2018 at 4:50 am
Keyur Kanade
Ansys EmployeeHi,
As ANSYS Engineer, we can not download from forum. Can you please insert some images.
Thanks!
Keyur
October 24, 2018 at 4:51 am
Keyur Kanade
Ansys EmployeeAlso moving this to Fluid Dynamics category for better response.
Keyur
October 24, 2018 at 9:21 am
DrAmine
Ansys EmployeeThe documentation contains an example how to apply DEFINE_EXCHANGE_PROPERTY. As you are directly writing the whole Kpq term you do have to account for everything on your own.
Are the drag laws implemented in Fluent for granular not sufficient for your application?
October 24, 2018 at 9:52 am
maliuzair
SubscriberSir,
I have solved first problem, but
I am still unable to include radial distribution function in the udf. Since there is a term of radial distribution function Go,ls in the equation. Can I recall it just like any other variable in the cell e.g. void fraction? How?
I am attaching screenshots for the udf and equation
P.S. I am just a beginner.
October 24, 2018 at 9:56 am
maliuzair
SubscriberDear Sir,
I have to include shape factor in the udf. I have accounted for that in primary phase and secondary phase interaction. But for solid-solid interaction; I dont know how to include radial distribution coefficient go,ls in the udf.
Best
October 24, 2018 at 12:05 pm
DrAmine
Ansys EmployeeThere is no documented macro to access the g0 function.
October 24, 2018 at 4:03 pm
maliuzair
Subscriberdear sir
can you advise how to solve the problem
Best Regards
2656
2120
1347
1118
461
