UDF for switching boundary condition/ valve opening/pressure build and release
    • Arunmanikam
      Hi All,
      I am simulating a cfd simulation where gas fills a chamber transiently and when pressure builds beyond a value, say 15 bar, one of the solid surface (which is meshed as sold valve) that separate the outer fluid domain with the chamber opens up. So i would like to create a udf where based on pressure it will switch from wall to interior (and both shadow and main surface merges) and solid_wall cell zone would become fluid zone type and simulation continues. Any pointers to udf would be helpful. Is there a quicker way to achieve this goal. Kindly let me know.
      regards,
      Arun
      Forum Moderator
      It's not quite that easy. The UDF needs to call a scheme command to trigger the change, and then make sure it doesn't revert to a wall when the pressure drops. I think someone's looked into this and reported back on here, good luck finding the thread.
  • The topic ‘UDF for switching boundary condition/ valve opening/pressure build and release’ is closed to new replies.
