UDF for volumetric heat generation in nuclear fuel rod
    • Anadi_Mondal
      Volumetric heat generation in a nuclear fuel rod can be written as q'''(z)= q'''_max*sin(pi*z/H), where q'''_max and H are constant. Volumetric heat generation(source/internal heat generation) only varies along the axial (z) direction. So I am writing udf for heat generation as follows,
      Am I in the right direction? Here I am using DEFINE_SOURCE macros. I don't think I need to use DEFINE_PROFILE macros as I am not applying a heat source on the wall.
      Anadi
    • DrAmine
      Do you want to apply that source in the cell zone? If yes: use DEFINE_SOURCE.
      Actually UDF is not required at all as you can do all that using Fluent Expressions. (espcially you are not linearizing anything).
    • Anadi_Mondal
      Hello Dr Amine,
      Thank you for your reply. So, are you saying that an expression like the one below will do my job for volumetric heat generation?
      source = 30400000[W /m^3]*sin(3.1416*z /3.5[m])
      Anadi
