UDF, heat transfer coefficient for Non-Equilibrium thermal model in porous media
    • Robbie Crosby
      I am trying to edit the value of the heat transfer coefficient under heat transfer settings for a Non-equilibrium thermal model in porous media. I am trying to write a UDF to do this however I cant get my UDF to come up when compiled. Does anyone have any advice for where I am going wrong. Thank you.
      #include "udf.h"
      #include "mem.h"
      #define Tsolidus 300.0
      #define Tliquidus 304.0
      #define L_f 250 //Latent heat of fusion
      #define UDM_RHO_F_PREV 0  // UDM index for storing previous rho_f
      #define UDM_LAMBDA_PREV 1  // UDM index for storing previous lambda
      DEFINE_PROFILE(h_sfq, c, t)
          real dl, epsilon, mu, nu, pr, rho_pcm, u, v, mu_pcm, k_pcm, Re_d, h_sfq, local_h_sfq;
          cell_t cell;
          dl = 0.0194; //Diameter Matlab
          epsilon = 0.85; //Porosity Matlab
          mu = C_MU_L(c, t);        // Laminar viscosity
          rho_pcm = C_R(c, t);          // Density
          nu = mu/rho_pcm;             // Kinematic Viscosity
          pr = nu/rng_alpha(1., mu, mu); // Prandtl Number
          u = C_U(c, t);
          v = C_V(c, t);
          mu_pcm = C_MU_L(c ,t);
          k_pcm = C_K_L(c, t);
          Re_d = (rho_pcm * sqrt(u*u + v*v) *dl) / (epsilon * mu_pcm);
          if (Re_d > 0 && Re_d <= 40)
              local_h_sfq = (0.76 * pow(Re_d, 0.4) * pow(pr, 0.37) * k_pcm)/dl;
          else if (Re_d > 40 && Re_d <= 1000)
              local_h_sfq = (0.52 * pow(Re_d, 0.5) * pow(pr, 0.37) * k_pcm)/dl;
          else if (Re_d > 1000 && Re_d <= 20000)
              local_h_sfq = (0.26 * pow(Re_d, 0.6) * pow(pr, 0.37) * k_pcm)/dl;
          else
          return local_h_sfq;
    • Federico Alzamora Previtali
      Are you having problems to get this to compile? Or is the UDF not working?
      If the former, are you getting any error/warning messages when you try to compile?
      If the second, I would look at the last section of your code, where you return the value of local_h_sfq only in the last else statement
