UDF library error when loading pemfc module.
    • GeorgeKellyBrunel
      I get this error when loading the built in pemfc module regardless of running in parallel or series.
      Error: The UDF library you are trying to load (C:PROGRA~1ANSYSI~1v194fluentfluent19.4.0addons\pemfc) is not compiled for parallel use on the current platform (win64).nnThe system cannot find the file specified.
      nnC:PROGRA~1ANSYSI~1v194fluentfluent19.4.0addons\pemfcwin643d_hostlibudf.dll
      Error Object: #f.
    • GeorgeKellyBrunel
      Has anyone experienced this and can help?
    • Keyur Kanade
      Please check compiler.
      Please search through forum and you will find many posts on UDF and compiler.
      Keyur
    • GeorgeKellyBrunel
      I don't quite understand this a built in module should that not just operate as its supposed to ?
    • GeorgeKellyBrunel
       I have gone through the compiler however, I have no idea what I'm meant to be looking for it was not written by me it is part of the module?
    • Keyur Kanade
      if you are having student version and if you are trying to access any special module, you may not have access to it.
      please check what is included in student version at
      https://www.ansys.com/en-in/academic/free-student-products?utm_source=studentcommunity&utm_campaign=studentcommunity&utm_content=Studentproduct&utm_source=studentcommunity&utm_campaign=studentcommunity&utm_content=Studentproduct
      Keyur
Viewing 5 reply threads
