UDF maco value does not align with contour of build in value
    • AnthonyB08
      Hi all,
      I am simulating an Eulerian-Eulerian model with momentum source/sink terms. To validate the insertion of the terms I am checking the logistics on pertinent variables, like axial and radial velocity. To access these velocities I wrote my UDF momentum as seen below
      Where the magnitude of the liquid velocity is as follows
      I then verify that this magnitude is working correctly by equating U_L to a user-defined memory as such
      However, when I compare U_DMI(c,t,33) with the velocity magnitude of liquid ( both shown in a contour plot) they are not the same... what am I doing wrong ... are my pointers incorrect?
      Forum Moderator
      Please can you post images of both fields?
