Tagged: ansys-fluent, turbulence-model, udf, udf-fluent
March 12, 2021 at 12:53 pm
Bibill
SubscriberDear all,nI would like to modify the distance function causes the model to behave as RANS in a Detached Eddy Simulation. Is there a possibility to impose our own distance function by means of a UDF ?.Thanks in advance !n -
March 12, 2021 at 12:58 pm
Aitor
SubscriberUnfortunately, it is not possible. Why do you want to modify the distance function?n -
March 12, 2021 at 1:04 pm
Bibill
SubscriberThank you Aitor for your answer !I'd like to solve with LES only in a part of the fluid domain, defined by an in-house criterion, and with RANS otherwise.n -
March 12, 2021 at 1:17 pm
Aitor
SubscriberIn that case, I recommend you to use SBES modeln4.14. Stress-Blended Eddy Simulation (SBES) (ansys.com)nThis is essentially an improvement of the DES model, and you can modify the blending function by means of User-Defined Functions (UDF).nIf the RANS - LES interface is known and the geometry is simple, Embedded Large Eddy Simulations (ELES) are also a good choice.n4.16. Embedded Large Eddy Simulation (ELES) (ansys.com)n -
March 12, 2021 at 1:23 pm
YasserSelima
Subscribersearch the udf manual for define_trans_flength macron -
March 12, 2021 at 4:50 pm
Bibill
SubscriberThank you very much !! These are the pieces of answer I was looking for !n -
March 13, 2021 at 11:58 am
YasserSelima
SubscriberYou are welcome! Good Luck!n
2688
2138
1355
1140
462
